Page 1 of 2 12 LastLast
Results 1 to 15 of 16
Thread: Large sediment in pipes - Pics attached
    DIY Junior Member
    Dec 2009
    Cypress
    Default Large sediment in pipes - Pics attached
    Hello,
    I have a 2 year old house. I have a lot of sediment in the plumbing pipes that is constantly clogging my showers and faucets. I think it is primarily coming from the hot side because there is very little sediment in the toilet tanks and the cold side of faucets are not clogging.
    I have one tankless hot water heater and a traditional water heater. I am having the problem in the areas that are powered by my tankless. I might be having the same problem in the other areas of the house but the sediment is building in the tank, so it's not clogging the faucets.... I'm not sure, just a guess.
    I have put some of the sediment in vinegar (distilled white vinegar) and it did not disolve. Below is a picture of what I am getting.
Size:  75.3 KBName:  Sediment 1.jpg
    Plumber jimbo's Avatar
    It could be water heater dip tube, but only if the unit is quite old....the dip tube problem dates earyl to mid '90s! Google dip tube to find out all about that
    DIY Junior Member
    Dec 2009
    Cypress
    It's a 2 year old tankless hot water heater.
    Jan 2008
    It looks a lot like calcium scale. Do you have hard water? Have you have the tankless serviced?
    DIY Member JKERN's Avatar
    Jan 2011
    Artesia NM
    Tankless hot water heaters have a nasty habit of building up calcium as well as disolved solids quickly due to the extreme and instant amount of heat that they generate. I have seen this in my field for several years now. Sometimes depending on your water makeup you will be able to just treat this with a standard cation softener but you would definetly need a reliable company to do a water analysis.
    It could be minerals precipitated onto the inside of the heating coil, which then "break" off when it cools and contracts, and then expands again during the next cycle.
    DIY Junior Member
    Dec 2009
    Cypress
    I haven't had the water tested.... and I'm on a well. Is there a way to test these particles myself? I read somewhere that if the particles disolve in vinegar, then it is calcium. I soaked the particles in Distilled White Vinegar and they did not disolve. I could be doing this wrong..... I am certainly not an expert.
    DIY Junior Member
    Dec 2009
    Cypress
    Is it possible to put some type of filter after the hot water heater to catch the debris?
    Jan 2008
    Assuming it is hardness/minerals, you need to treat the water. If you don't your tankless is going to have a very short life.
    Jan 2011
    Artesia NM
    It is certainly possible to put a filter post heater but that is not solving the problem like catcher says you first must asses your water condition and treat it pre heater to have any chance of success. Being in the water industry for some time I dealt with this sort of thing before and what is in your water now is what is causing your problem. Another thing you might consider is what type of stem pipe they used for your well. Some well drillers use galvanized pipe which over time can cause issues with other disimmilar metals down stream from it depending on your water analysis. Look up National testing labrotories they have a home owners kit you can purchase take your water sample and then mail it back to them.
    Architect Spaceman Spiff's Avatar
    Salt Lake City, Utah
    Check with some of your local universities. Many of them have water labs and will anaylize your water for a nominal fee. My local one does it for $15 for a basic, and $40 for a complete anaylsis.
    Spaceman Spiff aka Mike
    Dec 2009
    northfork, california
    He already analyzed his water problem with that picture of calcium broken off from the inside of the heating tubes [note the greenish copper tint on some] and you guys gave him the solution. Its only on the instant side ....Get rid of the instant heater. Nothing but trouble.
    I just added a real valve to the drain of my water heater, and got about a gallon of that same precipitate out of it. Tank water heaters, especially TALL ones, are natural filters. Not that drinking that in solution is a problem anyway.
    Put it in muriatic or lime-away, if you are still worried.
    A simple hardness test kit from a hardware store or pool company, for an aquarium etc. will give you a ballpark figure of hardness. If more than 3 gpg (about 60 ppm), you need a water softener to protect both water heaters and other appliances, clothes, fixtures etc..
    Water heaters don't filter hardness, they remove some by way of precipitating out of solution hardness minerals (calcium and magnesium) because of heating the water. Those particles become hard water scale and some break loose and if possible out of the tank.That is especially true of instant water heaters because there is no place to 'store' the particles and they are flushed out of the coil. Most instant water heaters have a very low maximum hardness that is allowed or the warranty is voided.
    Dec 2009
    Most instant heaters get installed without even a thought about water type. Then the HO does not of course do the maintenance. Then its a disaster.
    Electric tank water heaters are a perfect piece of engineering when you add the right anode and put in a real drain valve and plumb it to a drain.
    I have vacuumed and flushed as much as 3 gallons of stalagtites from water heaters. Imagine that running into your grohe faucet every day!
    In the Trades ilya's Avatar
    Dec 2009
    Akron Ohio
    Ballvalve do you attach a shopvac right to the drain on the hot water tank?
    not a licensed plumber
  1. Please help! Sediment clogging pipes
    By mward77095 in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 01-02-2010, 09:07 AM
  2. Leaky well pipe (PICS attached)
    By mrmichaeljmoore in forum Electrical Forum discussion & Blog
    Last Post: 11-08-2009, 03:52 PM
  3. Leaky well pipe (PICS attached)
    By mrmichaeljmoore in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 11-08-2009, 02:01 PM
  4. Shutoff Valve problem (pics attached)
    Last Post: 03-01-2009, 03:37 PM
  5. Sediment in hot water pipes?
    By sromero in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 05-09-2005, 01:54 PM
