Since there is no salt tank, there is no resin in it to soften water with.
And if you don't have a bacteria, iron or manganese problem, there's no sense in you using this equipment.
Will a kinetico sulfer guard hydrogen peroxide mach series system soften water? I know it is intented to remove odors, but wanted to understand if it will soften the water as well. If I plan to use it only for water softening do I need to get a brine tank?
I got the unit from a guy that needed it for remove a sulfer taste from his well water>
This unit has nothing to do with bacteria, iron or manganese. So even if HAD bacteria, iron or manganese, there's no sense you using this equipment. Not sure where that advice comes from but the Kinetico SulfurGuard is for sulfur (as the name might imply), not bacteria, iron or manganese. For bacteria, iron and manganese you would need a completely different equipment. Perhaps he misconstrued the use of H202 but experience in this equipment would make a difference in the advice given.
The SulfurGuard will work for limited sulfur removal and some other odor issues.
Because the Kinetico SulfurGuard removes sulfur not bacteria, iron, or manganese.
It's not called a Bacteria-Byebye, or an Iron-Irradicator, or a Manganese-Magnet.
The SulfurGuard is NOT meant for bacteria, iron, or manganese removal
He was asking if the Kinetico sulpher guard could be converted which of course, it can not. The post reads as though he got the unit from a friend or maybe even a yard sale with hopes of converting it. It's amazing how screwed up a thread can get when folks don't bother to read the posts.
You're right. I think he knows now that it can't be used to remove bacteria, etc.
