Results 1 to 6 of 6
Thread: Advice requested: wring an air compressor motor
    DIY Junior Member henny_316's Avatar
    Jan 2011
    Florida
    Default Advice requested: wring an air compressor motor
    I purchased a 60 gallon air compressor Kobalt 60-Gallon Cast Iron Oil Lubricated Air Compressor with Heavy Duty Induction Motor
    from Lowes. It didn't include the power cable. I purchased 3/C 12 awg SJ00W and a 20A/250V straight blade plug (I know this says 125V, I actually have the 250V). Where do I hook up the black, green, and white cables to inside the motor and the plug? Here are pictures I took and drew. The posts next to #3 are the only open posts that I see.
    Thanks for your help!
    Edit *The yellow wire off of post 4 isn't yellow, it's white.*
    Jan 2008
    The wires connect to the pressure switch, not the motor.
    Jan 2011
    Florida
    That actually makes a whole lot of sense. Although the pressure switch didn't appear to have a breakout panel where the motor does have a notch that is cable sized open (bottom right of the last picture.) I'll check that out again when I get home though. Thanks!
    Dec 2009
    northfork, california
    Never saw a Lowes rig without a plug. Was it a return?
    Absolutely looks like a 120v rig to me, coming from the pressure switch, where your 120v plug should come in.
    Better get better information or save that receipt for the burn out.
    Jun 2007
    North Carolina
    it is a 240 volt
    Dec 2009
    I just think we need a law about HP ratings. 3.7 HP is likely derived from a 1.5 HP motor plus its [fake] service factor plus a lot of fiction.
    How about those 5 HP shop vacs that plug into your 15 amp 120v outlet? WOW!
    Someone actually sued Sears years ago and won a settlement on this issue.
    Since its a dedicated 240v rig, it would have been nice if they ran a black and red wire to the motor along with a ground from the switch.
  1. converting air compressor 220v motor to 110?
    By dabiz7 in forum Electrical Forum discussion & Blog
    Last Post: 07-12-2010, 09:33 AM
  2. Cast iron motor adpater cracked Goulds Motor Apapter Part#1K310
    By on02151blueline in forum Pumps and Tanks Well Forum & Blog
    Last Post: 03-18-2010, 04:56 PM
  3. CSV recommendation requested
    By inspectorgene in forum Pumps and Tanks Well Forum & Blog
    Last Post: 07-02-2009, 06:06 PM
  4. Distance of Telephone (POTS) wring?
    By Lakee911 in forum Electrical Forum discussion & Blog
    Last Post: 03-12-2008, 08:40 AM
  5. Motor setup advice
    By joeyar in forum Electrical Forum discussion & Blog
    Last Post: 01-12-2008, 09:32 PM
