Results 1 to 4 of 4
Thread: Electricity power drained
    DIY Junior Member batlasi's Avatar
    Jan 2011
    CA, US
    Default Electricity power drained
    When I use Microwave oven, the electricity power drains to 50%. When I use washing machine, the electricity cycles as washing machine cycles. When I use garbage disposal, the electricity power surcharges. I started seeing these problems very recently. What could be wrong and how do I diagnose the problem.
    Electrical Contractor Jim Port's Avatar
    Aug 2009
    Maryland
    You need to call your power company ASAP. You may have a loose connection, typically the neutral. If the power company does not find anything then it is time to call an electrician and look for a loose connection in your equipment.
    I don't know how you are detecting power "drained" and "surcharged" but I agree with jim port that your symptoms could well be bad neutral in the house or from the pole, and this is an emergency situation. Call your electric company immediately.
    Jan 2011
    CA, US
    I called the power company and they came by and determined that the transformer was wired improperly which was causing leak. after correcting the wiring, everything is working fine.
    thanks for all the feedback.
  1. electricity and death
    By jwelectric in forum Electrical Forum discussion & Blog
    Last Post: 01-03-2011, 12:46 PM
  2. bad ground & electricity charges?
    By darque in forum Plumbing Forum Discussion & Blog
    Last Post: 10-21-2010, 04:00 PM
  3. I drained the system...and NOW I have water hammer????
    By Handymaner in forum Plumbing Forum Discussion & Blog
    Last Post: 09-18-2009, 10:06 AM
  4. Electricity is out in a bathroom
    By milik in forum Electrical Forum discussion & Blog
    Last Post: 12-28-2007, 02:28 PM
  5. Just Drained the cold water tank and pressure is poor after refilling
    By perry in forum Plumbing Forum Discussion & Blog
    Last Post: 06-27-2005, 08:06 PM
