Results 1 to 7 of 7
Thread: how to level an EXISTING cast iron tub
    DIY Senior Member bbillcee's Avatar
    Feb 2007
    NY
    Default how to level an EXISTING cast iron tub
    we have gutted the bathroom ( we are having the tub reglazed) and the ledger board that the cast iron tub rests on seems to be rotted out, i dont want to remove the tub because a mud job was put in after the tub and dont wanna mess it up
    the wall side of the tub has dropped about 3/4 of an inch
    i was kinda of thinking to lift that side of the tub a bit and wedging wood between the tub and the studs to keep it level....just want to know if u guys know a easier solution, i dunno if my idea would even work
    One who lurks Basement_Lurker's Avatar
    Jun 2007
    Victoria, BC
    For your tub to drop like that, you would have to have some serious rot going on there...and shimming the tub is a bandaid fix. A cast iron tub is a heavy beast and you need to support it properly.
    Broken promises don't upset me. I just think, why did they believe me? -Jack Handy
    www.blackbirdkitchenandbath.com
    Jan 2006
    Rosedale, Md
    I have to agree with "basement_Lurker" a lot of those cast iron tube should be supported by a ledger board AND wedges under the feet built in on the bottom of the tub, you may have major rot under the tub
    Feb 2007
    NY
    who usually installs the tub? the plumber or carpenter?
    Jan 2006
    Rosedale, Md
    Quote Originally Posted by bbillcee View Post
    Most of the time it is the plumber
    Nov 2009
    Victor, MT
    If you are pulling the tub you are better off putting in a new cast iron tub than reglazing what you have, the finish is much better and last a heck of a lot longer. It sounds like your project is growing on you and the new tub may seem like another ratchet up in size, but what you don't want to do is get done and not have the finish last.
    I sounds like you will have to do a lot more than you were planning on. You have a rot problem and unless you demo enough of the wall and floor to be sure all the rot is removed, you will continue to have problems. It isn't a matter of what you want to do, it's what you have to do.
  1. cast iron fitting installed in cast iron soil pipe
    By web_surfer in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 06-10-2009, 06:20 AM
  2. High iron level in well water
    By Roadtrash in forum Pumps and Tanks Well Forum & Blog
    Last Post: 11-25-2008, 10:47 AM
  3. Tub and Overflow drain, PVC to existing threaded Iron?
    By eva01 in forum Shower & bathtub Forum & Blog
    Last Post: 03-08-2008, 02:36 PM
  4. cast iron
    By woe in forum Toilet Forum discussions
    Last Post: 01-26-2006, 08:51 AM
  5. ABS to Cast Iron Hub
    By DVDiva in forum Remodel Forum & Blog
    Last Post: 09-12-2005, 02:54 PM
