The constant SFR has to be higher than the peak demand flow rate of multiple fixtures you may have running at the same time, not just one tub but, with 8 gpm there, you add anything else that may be used when the tub is filling. A 1.5 cuft softener has 12 gpm.
A 1.5 cuft uses a 10" x 54" tank. A 32K is a 1 cuft and they use a 9" x 48 tank.
