Thread: delta diverter
    DIY Junior Member larryf's Avatar
    Jan 2011
    Texas
    Question delta diverter
    i have an anti scald single lever shower faucet. when i turn it on water comes out the tub spout and the shower spout. when i push the diverter in it stops the tub spout. how do i stop water from coming out the shower spout until i push the diverter in?
    Is this a new install? Did it ever work right?
    Is there a separate diverter valve? If so, it may need service.
    If not, the likely problem is that you used either cpvc or pex piping to connect the spout. This has a smaller ID and creates enough backpressure to force some water out the showerhead. Otherwise, there's something partially clogging the path to the spout.
    Jan 2011
    Texas
    it is a delta faucet and the diverter valve is part of the main unit, but has a pusn in stem. this has been going on since it was new and i have just put up with it. it is an all copper install.
    Dec 2007
    Somebody didn't pay attention to proper distances between the spout and the showerhead or, the spout is plumbed with a restriction.
  1. Delta shower diverter
    By Brander in forum Shower & bathtub Forum & Blog
    Last Post: 09-05-2010, 06:26 PM
  2. Old Delta spray diverter problem
    By siffe in forum Plumbing Forum Discussion & Blog
    Last Post: 09-04-2009, 01:45 PM
  3. Removing old Delta spout / diverter
    By billwil in forum Shower & bathtub Forum & Blog
    Last Post: 09-10-2007, 07:11 PM
  4. Delta Shower Diverter
    By mynewacct in forum Shower & bathtub Forum & Blog
    Last Post: 09-30-2006, 06:49 AM
  5. Delta Monitor leaking, diverter bad
    By BuffaloSS in forum Shower & bathtub Forum & Blog
    Last Post: 07-01-2006, 07:01 AM
