Most culligan units should be done cleaning and back into service within about 90minutes to 2 hours depending on rinse and brine refill time.. if it is a digital control it should be close to that time frame.
Salt will depend on use... but from the past I have found that most if not all culligan units do not like a brine tank that is under half full... to this day I have yet to figure that one out... fleck units will work just fine with 1/2 a bag in the brine tank but the culligan's just do not work right when the salt gets much below the half way point of the 400 lbs tanks that they like to use..
