MichaelO
Engineer
Hello all,
Thanks much to Terry and all the contributors. I use this site often and have always found all answers I need in the archives but, this time, I need more help.
I have a washing machine installed in a closet that currently drains into a 1.5" drain, unvented. The run from the WM to the DWV stack/soil pipe is roughly 20', with correct slope, but generally horizontal. There is an S trap below the standpipe.
To the left of the washer/dryer closet is a utility room (boiler, et cetera) but, separated by a pocket door and chimney (thus no direct access), kitchen to right, dining room behind with built-ins I'm loathe to tear out. The WM drain exits through back wall, downward to crawlspace, and then a horizontal run to DWV stack on far side of house. Bedroom floor above so, I can't go straight up with vent.
I'd like to add a sink to the utility room, tied into the WM drain. While doing so, I would like to increase WM standpipe to DWV stack run to 2". I was thinking I could move the WM trap to the crawlspace, add the vent, which would follow the additional drain to the utility room, where I can run an auxiliary vent up, through ceiling, crawlspace (house is a Cape) and through roof.
The house is in Connecticut (IRC I believe). The project will not be inspected but, I'd like it functional, not smelly, to code, and capable of handling new fast pumping washing machines.
I'm on an iPad dealy and the only drawing program I've got, you use your finger so, this is really crude. Sorry. Black is existing, all else as noted. Drawing meant to be in perspective, from crawlspace, looking at back of washer. The gap between the washer is filled with a pocket door and chimney so, the access between both is through the crawlspace. I thought I had it with this plan but, then I saw something about IRC code not allowing auxiliary vent to run horizontal before flood rim of lowest served appliance so,...ummm, help, please.
Michael
Michael
