Results 1 to 6 of 6
Thread: Toilet Flange Levelness (picture attached)
    DIY Junior Member emcconne's Avatar
    Jan 2011
    Bolton, MA
    Default Toilet Flange Levelness (picture attached)
    I am remodeling my bathroom and have a question about the levelness of the existing toilet flange (picture attached). It is not level with the floor and is off by about 3/8" from back to front. In a perfect world this would be level and set flush with the finished floor. How bad of a problem is this and should I try correcting the problem which will require some serious work to fix due to access restrictions.
    Plumber jimbo's Avatar
    Note that the BOTTOM of the flange should be flush on top of finished floor. That flange is pretty far out of whack. Apparently it has been working, but at this juncture, I would not consider leaving it unfixed. You are just asking for trouble. It looks like white PVC, so removing it and installing straight are quite doable. If you need more help, especially it the PIPE is cockeyed, post more pics and let us know.,
    Jan 2011
    Bolton, MA
    I still haven't installed the 5/8" plywood that the flange would rest on so it looks high because of that. I am more worried about the levelness of it and whether or not it will seal to the toilet. I had planned to use a flange extender to get it up above the tile floor that will be installed on top of the plywood.
    Jan 2008
    I would fix it. Better to do it now rather than after the floor is finished.
    One who lurks Basement_Lurker's Avatar
    Jun 2007
    Victoria, BC
    You're already down to the subfloor. It would be pretty careless not to set a new riser that is plumb like it should be.
    Broken promises don't upset me. I just think, why did they believe me? -Jack Handy
    www.blackbirdkitchenandbath.com
    Yakima WA
    Would you accept this from a contractor? If so, go with it. If not, fix it now while it will be relatively easy.
  1. Vinyl floor at toilet flange sealing question (photo attached)
    By tom-rad in forum Toilet Forum discussions
    Last Post: 04-06-2010, 02:21 PM
  2. Flange Questions with Picture
    By sanrico in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 02-01-2010, 05:41 AM
  3. Fernco waxless toilet ring attached with silicone caulk?
    By jamminjoe in forum Toilet Forum discussions
    Last Post: 10-07-2009, 10:15 PM
  4. Tile floor closet flange issues. With picture.
    By coyote556 in forum Toilet Forum discussions
    Last Post: 07-27-2007, 03:44 PM
  5. 1/8" toilet drain slope issue with picture
    By KSHandyMan in forum Toilet Forum discussions
    Last Post: 06-20-2007, 01:31 PM
