Results 1 to 4 of 4
Thread: Mobile Home Toilet Still Runs with New Flapper Installed
    DIY Junior Member kailor's Avatar
    Dec 2010
    Huntsville, Alabama
    Default Mobile Home Toilet Still Runs with New Flapper Installed
    I have a mobile home toilet that still runs even after installing a new flapper. If I press down on the new flapper the water quits running into the bowl. I've cleaned the edge where the flapper rests. How can I fix this. Is there some kind of replacement part?
    Yakima WA
    You might supply a bit more information. Make and model of toilet and make and model of the flapper would be a good start.
    Dec 2010
    Huntsville, Alabama
    Thanks Gary. Can I find this information underneath the tank lid?
    Not all generic flapper valves will fit all toilets. But, the first thing to check is that there is enough slack in the chain, and that there isn't too much and it is caught underneath. On some, they have hooks and a round sleeve for those that don't have hooks. If you have hooks and you used the sleeve, you need to cut out the sleeve and only use the hooks.
  1. Are mobile home sinks different?
    By griffy335 in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 10-16-2008, 06:41 AM
  2. mobile home wall removal...
    By goldenroadrunner in forum Remodel Forum & Blog
    Last Post: 03-19-2007, 12:05 PM
  3. Vinyl siding for mobile home?
    Last Post: 03-05-2007, 01:27 PM
  4. New shower in Mobile home
    By Pewterpower in forum Shower & bathtub Forum & Blog
    Last Post: 09-17-2006, 07:09 PM
  5. Mobile Home Water Supply
    By Marshall in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 06-26-2005, 08:11 PM
