Results 1 to 5 of 5
Thread: Baseboard heater/wiring question
    DIY Junior Member meltz's Avatar
    Jan 2011
    ny
    Default Baseboard heater/wiring question
    Ok so here is what im trying to do lol.
    I am trying to hook this electric baseboard heater up. Its an older one that was here in ym house when i bought my place. Now my problem is there are two black wires. One black wire on top and one grayish/black wire on the bottom. I dont know which one do i connect to the black wire from the thermostat and which one do i connect to the white wire coming from the thermostat. I hope someone can help cause its buggin me badly lol
    Also where in the world do i put the copper ground wire, there does not seem to be a spot to place it. Usually there is a green screw to place the ground to but there is not one here.
    Thanks and looking forward to learning from this experience.
    Plumber krow's Avatar
    Feb 2008
    Ontario, Canada
    Connect the black wire with the solid black, connect white wire with the greyish black and ground wire to the phillipps screw at the very top of the baseboard in your first photo.
    It won't really matter which wire is which because the baseboard has 2 hot (power) wires(240v)
    Jan 2011
    ny
    great, thanks so much gonna give it a go tomorrow.
    National Electrical Code Expert/Speaker/Educator TheElectricalGuru's Avatar
    Oct 2008
    Hopefully you will also address the fact this NM Cable has no connector as it enters the heater. It also looks like the NM Cable is damaged as well.
    Paul W. Abernathy
    Founder of : TheElectricalGuru.com
    NEC Consultant
    ICC & IAEI Certified Electrical Inspector
    ICC & IAEI Certified Electrical Plans Examiner
    2007 Mike Holt Enterprises " Top Gun "
    NEC Expert to Mike Holt -2008 NEC Exam Prep DVD's
    IF the cable came TO the baseboard and then two wires went from there to the thermostat, then it would be an SPST thermostat, which should not be used for that application, and one end connects to one of the feed wires and the other to the heater. BUT, from what the pictures show, it should be an DPST thermostat, in which case BOTH wires connect to the heater's wires, and the "green wire" attaches to the metal somewhere.
  1. New Baseboard Heater install
    By 98ZJUSMC in forum Electrical Forum discussion & Blog
    Last Post: 11-29-2010, 01:28 PM
  2. Baseboard Heater Issue
    By spta97 in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 11-12-2010, 04:04 PM
  3. Baseboard Heater and misc wiring ???
    By Master Brian in forum Electrical Forum discussion & Blog
    Last Post: 10-11-2009, 08:50 PM
  4. Wiring baseboard heaters
    By milkman2010 in forum Electrical Forum discussion & Blog
    Last Post: 08-02-2009, 07:38 PM
  5. electric baseboard heater
    By hids2000 in forum HVAC Heating & Cooling
    Last Post: 07-15-2007, 07:34 PM
