Results 1 to 2 of 2
Thread: Shower whistling
Hybrid View
    DIY Junior Member Jwhitman's Avatar
    Feb 2009
    California
    Default Shower whistling
    A couple years ago I converted a tub into a shower. I replaced the shower valve with a Moen. The way it works is you turn the knob to the left to turn it on then adjust left or right for temperature. I am told this is common for hotels. Anyway, a few weeks ago it started to whistle. It seems like adjusting the temp helps and well as the flow at the head. The tub spout seems to seal well. Does this sound like I need to replace the cartridge ( if that's what it's called) in the valve or has something else changed in the plumbing. Any ideas appreciated
    Thanks,
    J
    If the tub spout is still there (sounds like it) and you are relying on the diverter in it to get the water to the showerhead, it's probably the spout.
  1. Whistling Tub Faucet
    By BrianC in forum Shower & bathtub Forum & Blog
    Last Post: 07-21-2010, 05:00 PM
  2. Whistling Shower
    By Kenekeb in forum Shower & bathtub Forum & Blog
    Last Post: 03-22-2008, 11:49 PM
  3. Whistling Gas Line to Pool Heater
    By mchaney in forum Plumbing Forum Discussion & Blog
    Last Post: 05-23-2007, 06:32 AM
  4. Whistling Pipes, Not the best music
    By 2Improve in forum Plumbing Forum Discussion & Blog
    Last Post: 09-04-2006, 08:01 AM
  5. whistling gas hot water heater
    By miriam in forum Plumbing Forum Discussion & Blog
    Last Post: 01-17-2006, 04:03 AM
