Results 1 to 2 of 2
Thread: Running Power to my Barn
    DIY Junior Member ntmare230's Avatar
    Jan 2011
    Winter Garden, FL
    Default Running Power to my Barn
    I have a barn that is approximately 600 feet from the meter. I have done some research and am willing to run 4/0 Triplex to the barn, but my question is will the 600 feet of 4/0 wire significantly add to my bill? If I have less than a 2% voltage drop, will the bill be basically the same as if it was 50 feet from the meter and I used a smaller wire?
    I appreciate your help,
    Freddy
    Jun 2007
    North Carolina
    Nothing wrong with the voltage drop at 2% but
    What size panel is going to be installed at the barn? Was this from a calculated load?
    Is there a disconnect such as a fuse panel or breaker panel at the meter?
    If there is a disconnect at the meter then triplex will not work as the neutral would need to be insulated and an equipment grounding conductor would be required.
  1. Running two power cables in same conduit
    By yaserhassan in forum Electrical Forum discussion & Blog
    Last Post: 10-21-2009, 02:32 PM
  2. Question regarding the running of high-voltage power cables
    By osx-addict in forum Irrigation / Sprinkler Forum
    Last Post: 11-01-2008, 02:24 PM
  3. Quick Help: Trenching Polyethylene out to Barn...
    By barnfield in forum Plumbing Forum Discussion & Blog
    Last Post: 06-24-2008, 06:10 PM
  4. Electric water heater for barn
    By DVMSteve in forum Plumbing Forum Discussion & Blog
    Last Post: 09-16-2007, 08:32 AM
  5. How to Set up Plumbing in a horse barn
    By heyitsme33 in forum Plumbing Forum Discussion & Blog
    Last Post: 12-03-2006, 09:05 AM
