Results 1 to 9 of 9
Thread: Electric heater control
    DIY Junior Member 801Sparks's Avatar
    Jan 2011
    Wisconsin
    Default Electric heater control
    My wife has an electric foot heating mat that gets a little too hot to keep her feet on. Can I use a standard electronc dimmer switch to lower the voltage to this 90 watt 120 volt resistive load, thus lowering the temp?
    Jun 2007
    North Carolina
    the short answer is no.
    Jan 2011
    Wisconsin
    Could you elaborate a little? Why is the 90 watt resistive heating element any different than an incandescent light bulb? Both are resistive loads with 100% power factor right? Is there something in the electronic square wave dimmer that wouldn't function properly?
    Jun 2007
    North Carolina
    My short answer is;
    Did it come with a dimmer? No
    Then one can’t be used on it.
    Just how do you propose installing this dimmer for this heat pad?
    No you can’t install the dimmer so it will work through the receptacle.
    Have you thought of folding a towel and placing it over the pad?
    Jan 2011
    Wisconsin
    A Lutron makes a 300 watt plug in lamp dimmer for about $10, it has a cord and plug on it.
    No wiring would be needed, therefore no NEC violation.
    My question is; will it work.?
    I'm sorry, but I don't think putting a folded up towel on an electric heating device sounds very safe.
    Dec 2009
    northfork, california
    Since heating pads and electric blankets come with built in rheostats, you would have been better off with a foot pad with such a control built in.
    Actually, a good dog bed warmer would have worked and they have controls. I think trying the plug in rig won't harm anything.
    The towel will just get as hot as the pad, how about a piece of lattice or some sort of gridwork that would allow some air to circulate and reduce trapped heat?
    The bottom of a plastic "flat" that plants come in from the nursery comes to mind as probably laying in the backyard. "REPURPOSE"
    Licensed Electrical Contractor Speedy Petey's Avatar
    Jun 2007
    NY State, USA
    Quote Originally Posted by 801Sparks View Post
    Why is the 90 watt resistive heating element any different than an incandescent light bulb? Both are resistive loads with 100% power factor right?....
    Just do it. You obviously only want to hear the answers you want so why bother asking.
    Dec 2009
    Thats a real new york city answer. He wanted help, not insults. What is your objection to the rheostat?
    Jun 2007
    North Carolina
    or is it an electronic dimmer????
  1. electric heater
    By DIY in forum Electrical Forum discussion & Blog
    Last Post: 01-09-2010, 10:13 AM
  2. Gas Hot Water Heater-Temperature control
    By jkcsanchez in forum Water Heater Forum, Tanks
    Last Post: 08-22-2009, 11:30 AM
  3. Electric Heater
    By Cookie in forum Electrical Forum discussion & Blog
    Last Post: 01-09-2009, 08:53 AM
  4. Electric Water Heater 30 or 40
    By jimqual7 in forum Plumbing Forum Discussion & Blog
    Last Post: 07-26-2008, 08:10 AM
  5. Electric H/W heater ???
    By Bigbobdallas in forum Plumbing Forum Discussion & Blog
    Last Post: 08-15-2006, 08:38 PM
