Results 1 to 6 of 6
Thread: Installing toilet repair flange
    DIY Junior Member Vega's Avatar
    Dec 2010
    California
    Default Installing toilet repair flange
    I posted a question a few days ago (leaking flange)and appreciate the replies. I have looked for a “repair flange” but the local hardware store does not have something like that, and it will be a few days before I can get to a plumbing supply, so I don’t know what they look like of if it would work. The existing 4" ABS is sound except all the metal has been stripped off. Does a repair flange slip inside the 4" ABS (3.75" ID) without changing the height off the floor? (This site is a great help by the way, Thanks)
    Jan 2008
    There are a number of types of repair flanges; I recommend you google "toilet repair flange" so you can get a better idea what is out there. Depending on what you have to work with, you might be able to install a new flange or a repair flange.
    Dec 2007
    This is what you want if the metal ring has rusted off of a ABS flange.
    http://www.oatey.com/Plumber/Shared/...nt+Flange.html
    Lowes has them
    That LOOKS like the flange to use, but the picture is not definite enough to tell. What you want is a "two piece" flange that fits around the lip where the old one was and then bolts together to "grab" it.
    Dec 2007
    That is exactly what that flange does!
    That is why I said, "It looks like it will work, but the picture is not precise enough". The picture looks like there is a "joint" on either side, but you cannot see if there is a bolt/screw holding them together.
  1. Toilet flange repair
    By emaciat0r in forum Toilet Forum discussions
    Last Post: 09-03-2009, 07:22 PM
  2. Toilet Flange Repair Issue
    By adambrich in forum Toilet Forum discussions
    Last Post: 01-13-2008, 01:14 PM
  3. Toilet Repair of PVC Flange
    By Harleyman in forum Toilet Forum discussions
    Last Post: 06-14-2007, 06:52 PM
  4. Installing a toilet flange
    By kwhitt1017@yahoo.com in forum Toilet Forum discussions
    Last Post: 01-25-2006, 04:23 PM
  5. subfloor repair and toilet flange question
    By Paul L in forum Toilet Forum discussions
    Last Post: 09-21-2005, 08:49 PM
