Results 1 to 5 of 5
Thread: Gas black pipe run?
    DIY Junior Member Cincy_DIYer's Avatar
    Jan 2011
    Cincinnati
    Default Gas black pipe run?
    I need to move my gas water heater(WH) over about 6 feet to make run for a new location for a gas dryer hook-up. Currently a single 3/4" line is feeding two tees of 3/4" lines which feed the dryer and WH. Each, dryer and WH have 1/2" reducers at the end of the lines.
    Can I run both the dryer and WH off of a single 12' x 3/4" line reducing the line to a 1/2" at the end of each feed? I don't want to starve either of two units which could run at the same time. The WH is a 50 gallon 40,000btu unit.
    thanks,
    As a practical matter, probably yes, but the theoretical answer would require more information than you have given us.
    Jan 2011
    Cincinnati
    information such as?
    distance from the meter to the LAST connection in the system, and sizes of ALL the pipes to the point where the dryer connection is made to the main line, being two of the major ones.
    DIY Junior Member plummen's Avatar
    Jan 2012
    In a bunker under a non descript plumbing shop southeast of omaha
    At what point does your gas line get reduced to 3/4"
  1. Framing Around Black Gas Pipe
    By DigitalJim in forum Plumbing Code Questions
    Last Post: 11-26-2010, 08:12 AM
  2. Black Iron Pipe
    By Soto in forum Boiler Forum
    Last Post: 05-13-2010, 08:28 AM
  3. Black Gas Pipe --Insert T :how is it done?
    By mduval in forum Remodel Forum & Blog
    Last Post: 07-01-2008, 06:40 AM
  4. Gas black pipe
    By rockycmt in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 01-04-2008, 08:38 PM
  5. Black Pipe
    By Ed from chicago in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 02-15-2006, 05:08 AM
