Results 1 to 2 of 2
Thread: wheems Powervent 2 pressure switch problem
    DIY Junior Member woodbury's Avatar
    Jan 2011
    Irvine, ca
    Unhappy Rheems Powervent 2 pressure switch problem
    LED blinks 4 times and it says it means "pressure switch open".
    I have to unplug and plug in it back to make it work.
    It works for a while and it blinks 4 times again for same problem.
    I think pressure stitch prevent water heater from automatically power-on.
    What should I do? Oh.. typo. Rheems, not wheems.
    If this is a power vented unit, it is likely there is either a blockage in the intake or exhaust line, or a broken piece. When the burner comes on, the exhaust fan comes on to move the exhaust. There is a pressure switch safety circuit that detects the fan is on. If that switch doesn't close, it will shut the system down. It could be a bad switch, bad fan, or an obstruction or broken pipe somewhere, preventing the pressure to build up as a result of the fan motor running. It could even be the fan blades may have broken, and can't move enough air to close the switch. Checking the switch should be easy if you have and understand how to use a multimeter.
  1. Pressure Switch Problem ( I think )
    By frankap in forum Pumps and Tanks Well Forum & Blog
    Last Post: 05-01-2010, 04:28 PM
  2. Pressure switch problem or something else???
    By SergioMastro in forum Pumps and Tanks Well Forum & Blog
    Last Post: 08-05-2009, 07:48 AM
  3. Pressure Switch Problem
    By boryst05 in forum Pumps and Tanks Well Forum & Blog
    Last Post: 07-16-2007, 10:46 AM
  4. Pressure switch problem??
    By Marster in forum Pumps and Tanks Well Forum & Blog
    Last Post: 05-18-2006, 02:30 PM
  5. Pressure switch problem
    By 2cycle in forum Pumps and Tanks Well Forum & Blog
    Last Post: 04-26-2006, 08:43 AM
