Thread: backwater valve
    DIY Junior Member maddon's Avatar
    Dec 2010
    New brunswick ca
    Default backwater valve
    am i allowed to place a valve behind a grey water drain for upstairsdrain
    adding new bathroom downstairs . (split entrance, sewage drain on basement floor)
    putting false floor to run plumbing would like to be sure??
    I have no idea what you are asking about. But normally, the backwater valve would be for the LOWER level fixtures and the upper level would connect downstream from it so they would work normally even if the backwater valve was closed because of a flood condition. An entire bathroom is NOT a "gray water drain" system.
    Dec 2010
    New brunswick ca
    down spout from mainfloor bathroom is in front BWV,
    but i think you answered my question
  1. Backwater Valve
    By dlarrivee in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 06-25-2011, 11:52 AM
  2. Backwater Valve
    By chas22 in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 03-03-2009, 06:32 PM
  3. Backwater valve installation. Please advise
    By Pan in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 02-28-2008, 09:14 PM
  4. double check valve same as backwater valve ?
    Last Post: 02-26-2008, 07:14 PM
  5. What kind of backwater valve to use ?
    Last Post: 02-22-2008, 07:21 PM
