What pressure do you have in your pressure tank? It should be set to 1-2 pounds less than the turn-on pressure (measured with the system pump off, a valve open to relieve all water pressure in the system). If the tank is set too low, or the bladder is shot, there is no air in the system to allow a gradual build-up of pressure since water doesn't compress to any extent readily measurable.
