Results 1 to 2 of 2
Thread: PVC Venting and condensation line
    DIY Junior Member PlumbingHelpme's Avatar
    Dec 2010
    PA
    Default PVC Venting and condensation line
    I'm thinking of getting a Bosch C 1050 ES LP condensing tankless water heater. It is recommended that if the PVC exhaust is longer than 6' horizontal that you have a condensation drain in the exhaust vent. The length is going to be closer to 15'
    The only condensation drains I've seen for 3" venting are stainless steel.
    Can I use pvc snap T to make one ? and am I correct that the trap that the drain is connected to is what prevents the exhaust from coming through the drain ?
    Or are you supposed to connect the PVC to the stainless steel condensation drain units.
    Jason
    DIY Junior Member Tom the Apprentice's Avatar
    Jan 2011
    Edmonton, Alberta, Canada
    To my knowledge, you could use Stainless steel or PVC venting (Type "BH")
    In Canada, it's certified to CSA 636 for use in venting. As for keeping the exhaust (Products of combustion) from coming through the drain, a trap is used. This way, the water seal in the trap will not allow the carbon dioxide in the products of combustion to enter the living space.
    Check the owners' manual to make sure the unit will allow the length of vent you are proposing.
    Hope this helps!
    -Tom
  1. 3 Tanks In A Line: Venting
    By molo in forum Water Heater Forum, Tanks
    Last Post: 09-24-2009, 09:04 AM
  2. Venting a WC waste line horizontally II
    By Jhall in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 09-10-2009, 06:42 AM
  3. Venting a WC waste line horizontally
    Last Post: 08-27-2009, 01:07 PM
  4. wet venting a tub into a toilet line
    By brettalder in forum Toilet Forum discussions
    Last Post: 04-20-2009, 10:18 PM
  5. Venting a horizontal line with height restriction
    By Mikey in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 07-02-2006, 05:22 PM
