Eva Shanley
My husband and I had our upstairs bathroom gutted and remodeled 2 months ago. I knew there was a problem with the toilet (American Standard Champion 4) when the sewer smell started and moisture on the floor on either side of the toilet in a certain spot. We called the contractor back and he replaced the seal. The problem continued, at which point we gave up and called a plumber. Plumber pulled the toilet and showed me how the existing seal was a mess and wasn't even sitting on the flange properly. Sorry if I use incorrect terms at times but I know nothing about plumbing. I watched the plumber install a new seal with a sleeve on it, and also noticed myself that the flange was not tight to the floor. He added some screws so the flange fit tight. From reading many forums I knew the flange should be even with the floor which it is. Since we put the new toilet in, you can hear the washer drain and the sump pump run in the toilet; water in the toilet bowl moves back and forth but does not seem to lose any volume. The plumber said he had no idea why we would hear the noise. I'm still getting some moisture between the toilet and floor, but is not constant. I'm thoroughly confused as to which direction to move in next. I'm not sure at this point if the toilet is defective or not. As we've already spent a fortune on this remodel, I hate to call a plumber back again if he has to guess to figure out what's wrong. I should be enjoying this new bathroom and I hate it. Any idea how to test anything to find out what's actually going on here? Any advice would be most appreciated. Thanks!
