Results 1 to 9 of 9
Thread: Question About Removing Bathtub Skirt
    DIY Junior Member SoonerLawyer's Avatar
    Dec 2010
    Austin, TX
    Default Question About Removing Bathtub Skirt
    Hi everyone,
    I am in the process of replacing bathtube fixtures. The bathtub is acrylic with deck mounted fixtures. There doesn't appear to be an access panel to the tub but it looks like I can gain access through the skirt on the front of the tub. The issue is that I don't see any screws or bracket to remove the skirt. It looks like it is a rectangular piece of acrylic with a line along the length of the tub as well as down the left side of the front of the tube. Do I just take a knife along those lines to break the seal and then gently pull the piece of acrylic away from the tub? I had always thought skirts were held with screws which is why my tub is throwing me off a little. Any help would be greatly appreciated.
    Robert
    Aug 2009
    South*East
    It's hard to say what you have without a picture. I have seen some held in place with a strip of Velcro.
    John
    Dec 2010
    Austin, TX
    Here are a couple of photos of the tub and the seams I was talking about.
    Aug 2009
    South*East
    Definitely not held in place with Velcro. The best way to access the faucet may be through the wall behind the tub.
    John
    Dec 2010
    Austin, TX
    The other side of the wall has some built in shelving that would have to be removed. I was hoping to avoid doing that but probably doable if that is the better way to access the faucet.
    Quote Originally Posted by SoonerLawyer View Post
    If you do that, it would be a perfect opportunity to build a secret compartment or two to store valuables. Might help turn a minus into a plus..
    HRG
    The skirt may be held in place with the silicone grout, but it could also be glued with construction adhesive, which means the skirt COULD be damaged during the removal. If I had to do anything, I might try removing the smaller end panel first, that would then give you access to the back of the skirt to see how it is fastened.
    Dec 2010
    Austin, TX
    Quote Originally Posted by HomeRepairGuy View Post
    HRG
    Good idea of course I would actually need some valuables first!
    quote; Good idea of course I would actually need some valuables first!
    From your "name" I would assume you are a lawyer from OK, (Sooner, boomer), and should have at least some valuables if you are a successful lawyer, that is.
  1. Need help removing grab bar from bathtub
    By steveg1999 in forum Shower & bathtub Forum & Blog
    Last Post: 09-03-2009, 12:34 PM
  2. Removing a Bathtub
    By Book3 in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 08-29-2009, 08:55 AM
  3. Removing a Bathtub Spigot
    By sbu91 in forum Shower & bathtub Forum & Blog
    Last Post: 06-28-2008, 08:24 AM
  4. Problems removing a bathtub spout
    By namrono6 in forum Shower & bathtub Forum & Blog
    Last Post: 01-31-2007, 08:27 AM
  5. Removing a bathtub
    By HoneySuckle in forum Shower & bathtub Forum & Blog
    Last Post: 11-18-2006, 06:56 AM
