Results 1 to 7 of 7
Thread: beacon morris toe kick heater
    DIY Junior Member krisluvinglife's Avatar
    Dec 2010
    newburgh, ny
    Exclamation beacon morris toe kick heater
    the blower fan in my BM toe kick heater has become extremely loud (i'm not complaining after 20 years of steady work)...however before we can get around to replacing it, can i just disconnect the electric so the fan doesn't blow anymore or will that create a problem with the pipes getting too hot under the cabinet?? thank you for all of your expertise people!! awesome website!!
    If it was designed to always have the fan on while the heating elements are on, then disconnecting the fan might just start to test the safety overheat circuits (or the fire department response)! Probably not a good idea.
    Aug 2009
    South*East
    I don't think it could cause a fire. That's like saying having drapes in front of copper fin baseboard would cause a fire. With out the fan running it won't be very effective in heating the room.
    John
    quote; If it was designed to always have the fan on while the heating elements are on, then disconnecting the fan might just start to test the safety overheat circuits
    That would only be true if it were an electric heater, NOT the hot water one she has. And an electric heater could be discontinued by turning off the power to it, anyway. A toe space heater without a fan is just a small section of baseboard which will NOT overload safety circuits or cause a fire.
    Dec 2010
    newburgh, ny
    thank you so so much for response!!!
    Dec 2010
    newburgh, ny
    thank you so so much for response!!! now i need to replace the motor and fan>>> any help would be greatly appreciated!!! thanks again!!
    A source, such as Grainger's, if yours will sell to a noncontractor, (ours won't), should have a replacement motor if you take it in for comparison.
  1. Toe kick HW heater
    By rockycmt in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 03-19-2009, 06:28 AM
  2. Kickspace Heaters (Beacon Morris)
    By CTWeekendWarrior in forum HVAC Heating & Cooling
    Last Post: 11-15-2008, 07:01 PM
  3. what type of hose for a toe kick heater?
    By jpb116 in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 10-26-2008, 06:50 AM
  4. my toe kick heater won't get hot? Help`
    Last Post: 04-28-2008, 11:52 AM
  5. Beacon Mixer Valve-Where to buy?
    By rstier in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 05-02-2005, 06:37 AM
