Results 1 to 2 of 2
Thread: Lukewarm hot water in house after valve change in shower under construction
    Default Lukewarm hot water in house after valve change in shower under construction
    Sorry if this is a repost, it looks like the first post did not take...
    We installed a rough-in valve in our master bathroom, we have only put the test cover on to the valve as the construction is still ongoing. Since the installation, the hot water in the other bathroom only gets up to lukewarm, not hot. Nothing else has changed. I think air got in the lines because I had a couple of faucets open when I was replacing my valve, I don't know if that is a big deal.
    Whoever installed the rough in body did NOT install the bypass plug to prevent that from happening. If the plug has been lost or dislodged, you can install the valve cartridge to correct the problem.
  1. Shower valve that's easiest to install in block construction
    By bigwooo in forum Shower & bathtub Forum & Blog
    Last Post: 12-04-2010, 02:10 PM
  2. Only lukewarm water in tub and shower
    By barkeleyboy in forum Shower & bathtub Forum & Blog
    Last Post: 01-05-2010, 09:46 AM
  3. Shower hot water issue - hot from tub faucet, lukewarm from shower head
    By mikea128 in forum Shower & bathtub Forum & Blog
    Last Post: 09-29-2006, 06:37 AM
  4. Well House Construction Concerns
    By JeffSimpson in forum Pumps and Tanks Well Forum & Blog
    Last Post: 12-31-2004, 06:58 PM
