Thread: pulling wires in a wall
    DIY Senior Member Taylor's Avatar
    Mar 2005
    Northern Joisey
    Default pulling wires in a wall
    I believe the rule is max 2 wires per hole when pulling through a stud wall. Can I mix 12g and 8g wires in the holes? The holes for the latter are big, more than 2", and I'd rather just pull an extra wire through those than drilling yet more holes in this wall that carries all the conductors from the main panel.
    Thanks.
    Jun 2007
    NY State, USA
    There is NO "max 2 wires per hole" rule. There are derating rules, and many will argue that pulling through holes in studs does not apply, but IMO that does not matter if you keep to no more than four cables to a hole with up to #10 conductors. There are code reasons for this which I won't go into right now.
    I must ask, where are you drilling 2" holes in framing? 2x6 walls? I hope they are dead center.
    Mar 2005
    Northern Joisey
    Thanks.
    The holes are in 2x6 walls, it's in a basement so the only load is drywall, maintaining 1-1/4" distance from the edge etc.
  1. Two wires
    By jc60618 in forum Electrical Forum discussion & Blog
    Last Post: 09-27-2010, 08:27 AM
  2. Pulling low voltage wires through metal studs
    By Ian Gills in forum Electrical Forum discussion & Blog
    Last Post: 08-31-2009, 03:54 PM
  3. Pulling my hair out
    By kcwright1979 in forum Pumps and Tanks Well Forum & Blog
    Last Post: 07-12-2009, 09:15 AM
  4. Pulling the pump
    By Glaswegian in forum Pumps and Tanks Well Forum & Blog
    Last Post: 01-02-2008, 10:00 PM
  5. Pulling a submersible pump
    By abikerboy in forum Pumps and Tanks Well Forum & Blog
    Last Post: 05-23-2006, 12:57 PM
