Page 2 of 2 FirstFirst 12
Results 16 to 24 of 24
Thread: Water Heater Tank Question
  1. #16
    Dec 2009
    northfork, california
    When the junk valve breaks off like a sharpened spear, and its 4" into the base where one may grab it and actually turn it without further shattering, and the internal wrenches are an hour away, and the house gets heated with the rig, the chop and fix makes sense.
    Some of the tops come off easy as their is a pvc linerbag inside, so economically, not trying to observe the tank and changing a good water heater that someone may have stepped on is a extraordinarily foolish move.
    But its a goldmine for the plumber that got to take the unit home or for the guy that picked it up on the curb.
  2. #17
    smithwatson
    Guest
    Many new technologies are available in the market to fix and repair the HVAC system. By not only getting the new information about technologies, it is very difficult to implement and restore the HVAC system. It's good to hire a HVAC certified professionals.
    Removed link: Terry Love
  3. #18
    Mar 2011
    Houston, TX
    Could I have some eggs too ?
    What does your post have to do with water heaters ?
    Or did I miss something ?
  4. #19
    DIY Senior Member Reach4's Avatar
    Sep 2013
    You did. It's an attempt at a sneaky ad.
  5. #20
    DIY Member ankhseeker's Avatar
    Oct 2013
    California
    My smart ass comment is that if one is imploded and the other is bulging, maybe you should switch them for awhile. Maybe they will fix themselves. (ducking....)
  6. #21
    Mar 2011
    Houston, TX
    Quote Originally Posted by Reach4 View Post
    I got that part.
    That is why I wanted eggs to go with my Spam.
    I did not see how this Forum was the best place to post a ad for HVAC.
    Thanks Terry, You are the best.
  7. #22
    DIY Member Wallijonn's Avatar
    Jun 2013
    Arizona
    Why isn't the ground wire also connected to the hot water side? If the loop is long enough it shouldn't transfer any heat to the cold pipe.
  8. #23
    Often, the hot and cold are bonded to the panel at the water heater location.
    There is no worry about conducting heat there. It's more to do with grounding.
  9. #24
    Jun 2013
    Arizona
    I was thinking along the lines of,
    Water heaters that rust out quickly might be connected to water pipes that are not grounded. Hot water pipes are not grounded in many homes. To get 'rid of stray current corrosion, jumper between hot and cold pipes with #6 solid copper wire. And check that cold water pipe is grounded to main panel and to grounding rod.
    http://waterheatertimer.org/How-to-w...-120-Volt.html
    Most electricians automatically bond the cold water line but do not ensure that the cold and the hot water lines are metallically interconnected through mixing valves in the plumbing fixtures. Since Section 250.104(A) requires all water-piping systems to be bonded back to the service, and hot or cold water lines are not specifically mentioned, both hot and cold water lines must be bonded and connected back to the building service.
    http://waterheatertimer.org/pdf/wate..._grounding.pdf
    My problem is that I don't have a separate ground wire going to the cold water line (there's a copper jumper between cold and hot water pipes) and I don't have a lightening rod on the roof. (Most homes in Phoenix don't have them, just as most homes don't have gutters, and most homes have the AC on the roof. Weird, I know...) I figure the ground wire in the conduit wiring is being used to ground it. I hope there's no harm connecting the WH ground screw to the cold water pipe. (I work with electronics and fear ground loops.)
    Electric water heaters have [a] ground screw. Make sure ground wire from main panel is connected to screw. Attach ground wire from both hot and cold pipes to ground screw.
    ibid.
    Gutters and a lightening rod are on the schedule for the future. I have no trees near my house that can attract lightening...
    Now if I can only figure a way to install heat traps since my water pipes are right above the WH, so they go straight down to the WH inlet and outlet... Shark hoses aren't long enough, so I'll have to find flexible copper that is long enough. Heck, my WH doesn't even have an expansion tank...
    And yes, I will be replacing the WH circuit breaker with a new one when I install my WH this weekend.
  1. question on water heater venting (orphaned water heater)
    By harveymasons in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 08-23-2010, 06:11 AM
  2. Replies: 4
    Last Post: 07-10-2009, 01:43 PM
  3. Gas LP water heater , can you add temp aux tank
    By dlarson in forum Water Heater Forum, Tanks
    Last Post: 04-15-2009, 03:03 PM
  4. New water heater, existing water softener, expansion tank needed?
    By dhancock in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 01-12-2009, 08:09 PM
  5. Tankless or tank water heater
    By willl in forum Tankless Water Heater Forum
    Last Post: 12-10-2008, 03:53 PM
