Page 2 of 2 FirstFirst 12
Results 16 to 20 of 20
Thread: Shower Glass Block Wall
  1. #16
    Jul 2009
    North Vancouver, BC
    Post(s) deleted by John Whipple
  2. #17
    DIY Junior Member StatManLV's Avatar
    Nov 2010
    Cedar Rapids, IA
    Quote Originally Posted by johnfrwhipple View Post
    Will you have an open entry (ie no curtain or door)?
    With the pony walls design and the direction of the water I would not be installing your 1"x6" granite on top of the pony wall but instead installing it flush with the top of the pony wall and pitched into the room in all directions. These glass blocks will need to anchor to the ceiling in my opinion or you will have a weak structure.
    This Pony wall as well should be a tank to begin with. What size glass block will you be using?
    Do you have access from below? Who will be doing the framing or wood work?
    What size tile have you chossen? For this layout I would be looking at 4"x4" or 2"x2" tile for a standard drain or Kerdi Drain. If you prefer larger format tile a channel drain or some extra tile cuts will be needed to make the pitch work.
    Are you building a bench in that back corner? Any Shampoo niches?
    JW
    Open entry
    I know what flush means, but not sure I get the distinction your talking about.
    6x6 for walls, 1x1 or 2x2 for floor.
    The glass block is 8x8x4. One wall will have 24 blocks, the other 18. Wanted to stop these walls about a foot short of the ceiling, any way to do that?
    Yes, a bench in the corner. Two niches.
    No access from below, and I'm doing the framing.
  3. #18
    Jul 2009
    North Vancouver, BC
  4. #19
    Nov 2010
    Cedar Rapids, IA
    So it's time to build my pony walls. One will be 25" wide and 35" tall, the other will be 33" wide and 35" tall. Both will be perpendicular to the floor joists and each will attach to full height walls on one end. Is there a way to make these walls rigid without opening up the floor to attached studs to the floor joists?
  5. #20
    Jul 2009
    North Vancouver, BC
  1. glass block in shower area
    By jec in forum Shower & bathtub Forum & Blog
    Last Post: 07-24-2010, 02:03 PM
  2. Glass Block advice
    By solarant in forum Shower & bathtub Forum & Blog
    Last Post: 05-27-2010, 06:06 PM
  3. Mortar Glass Block Shower
    By bighornram in forum Shower & bathtub Forum & Blog
    Last Post: 10-16-2009, 08:38 PM
  4. Frameless shower door and Glass Block install
    By crosby1 in forum Shower & bathtub Forum & Blog
    Last Post: 02-07-2008, 05:36 PM
  5. Attaching shower heads to glass block?
    By Jabela in forum Shower & bathtub Forum & Blog
    Last Post: 06-22-2005, 03:04 PM
