Results 1 to 7 of 7
Thread: Adding Shower to Existing Roman Tub set up...
    DIY Junior Member wacosta's Avatar
    Dec 2010
    washington
    Default Adding Shower to Existing Roman Tub set up...
    I've got a beautiful whirlpool tub, but now need to add a shower set up. Will use exposed pipes once we figure this out.
    So the question is -
    Can I add a diverter to the existing set up (under the faucet perhaps or in line is possible) and plumb from that to a shower?
    I really don't want to replace the existing fixtures.
    Other option is to be a little funky and add an exposed shower on the other end of the tub (have a good 18" of oak decking and supply line access there. Is it possible to create an exposed shower set up? I really am on a tight budget and don't want to spend any more than I have to.
    One who lurks Basement_Lurker's Avatar
    Jun 2007
    Victoria, BC
    what you need to be done is not going to be easy nor cheap.
    Broken promises don't upset me. I just think, why did they believe me? -Jack Handy
    www.blackbirdkitchenandbath.com
    Plumber jimbo's Avatar
    You went off the tracks as soon as you use the words "roman tub" and "tight budget" in the same sentence.
    You'll need something like a circular shower curtain to contain the spray in the tub confines. This look doesn't please everyone. Then, unless there is already something like a handspray you could extend, the easiest thing might be to replace the tub spout with one that has a shower hose, diverter, and takeoff in it.
    without a picture showing your existing faucet, there is no way we can comment on whether it is adaptable to a shower unit. The most likely scenario is that it IS adaptable, but then the question becomes how do you do it? To answer that we need the picture.
    Dec 2010
    washington
    Thanks for all the replies. Will post a few photos soon. Appreciate all the help.
    Already have the circle shower curtain (an ugly but functional necessity).
    Should have gotten the rectangular one, it looks like it was made for the tub at least.
  1. Adding a Shower to Roman Tub
    By jen in forum Shower & bathtub Forum & Blog
    Last Post: 01-03-2010, 12:25 PM
  2. Adding a shower to an existing jetted tub
    By jodielyn in forum Shower & bathtub Forum & Blog
    Last Post: 08-15-2009, 01:52 PM
  3. Adding fitting to existing drain
    By chukakid in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 02-26-2009, 03:48 PM
  4. adding guest house to existing well
    By jk13 in forum Pumps and Tanks Well Forum & Blog
    Last Post: 11-26-2008, 09:34 PM
  5. adding shower to existing tub
    By skyscooter in forum Shower & bathtub Forum & Blog
    Last Post: 01-16-2006, 07:58 AM
