Page 1 of 2 12 LastLast
Results 1 to 15 of 25
Thread: Bathtub drain slip nut
    Question Bathtub drain slip nut
    Hi,
    I removed my old tub. I couldn't get the drain out of the tub, so I ended up cutting the brass pipe that connects to it from underneath. I then removed the tub and the slip nuts.
    The remaining tub drain has the threaded sanitary-tee-like connection, which goes into a lead-filled joint. I went to Lowes and picked up a new brass tub drain kit, but the slip nuts from the new kit don't thread onto the old sanitary tee. Here is a picture (obviously old slip nut on right).
    Both slip nuts seem to fit fine over the new brass pipe, but the the new nuts will not thread onto the old brass tee connection.
    Does anyone know what I need to look for when getting the new slip nuts to ensure that they will fit? I thought this sort-of thing was standard.
    One who lurks Basement_Lurker's Avatar
    Jun 2007
    Victoria, BC
    Quote Originally Posted by supermattthehero View Post
    Heh. So why can't you use the new SJ washers with the old nuts? If you look closely, you will see that the old nut uses a fine thread, and the new nut uses a fine thread.
    Broken promises don't upset me. I just think, why did they believe me? -Jack Handy
    www.blackbirdkitchenandbath.com
    Anyone else?
    Either use the old nuts, with "thinner" rubber washers, or replace the entire drain. The nuts were proprietary to that drain and you will not find fine thread nuts which will fit it.
    Welp, nuts are a moot point now. I tried to remove the drain from the lead/oakum joint, and in doing so (with a hammer, screwdriver, etc) cracked the cast iron pipe about 8" below the finished floor. Now I've created some work for myself, since this is on a concrete slab. Darn it.
    You violated one of my cardinal rules. "ALWAYS stop, and call me, about 2 minutes before you reach your level of incompetence, otherwise you WILL create a much more difficult job than when you started, and make my job a LOT harder".
    Dec 2007
    Welp folks we've got a big job now!
    Busted it up. Here's the pics. I assume the easiest thing to do would be to cut off the cast iron pipe BEFORE the barrel connector (and not try to force a donut in there, etc), and just use a mission coupling? Name:  DSCF0038.jpg
Size:  53.6 KBName:  DSCF0041.jpg
    Dec 2007
    I'd bust a bigger hole. Where does the drain need to be for the new tub?
    Quote Originally Posted by Redwood View Post
    There are two holes...the bigger one is what I busted up this morning. The smaller one is where the drain actually came up...and the little tiny trench that comes off of that is where the actual bathtub drain extends.
    Quote Originally Posted by hj
    Waiting for phone number. Should be an easy commute to VA from AZ.
    Jun 2007
    Victoria, BC
    good lord what happened...i posed a simple solution but you went in the opposite direction all together!
    Quote Originally Posted by Basement_Lurker View Post
    The problem was that there was only one "old" nut available, and I needed two. If it was as simple as you may have assumed, I wouldn't have posted here to begin with.
    Kind-of reminds me when I go to the hardware store with a particular fastener, and I say to the salesperson, "I need a screw like this." One time the guy said to me, "Well, what's wrong with that one?" It makes me want to say "Gee, you know what, you're right! I had the answer right here in my hand all along!"
    Jun 2007
    Victoria, BC
    Ahh, well you should have replyed to my original reply with that information. Anyways you seem quite agitated, so I won't dwell in this thread, but had you replied with that little bit of information, I would have told you to simply cut off the old tee, leaving the riser stub in place, and simply couple on the new drain tee with a sheilded rubber coupling. Good luck with your repairs.
    I *am* quite agitated. Don't take it personally. This remodeling stresses me out.
    Just cut off the pipe. It's amazing it drains at all.
Size:  56.0 KBName:  DSCF0043.jpg
  1. Question 752: Tub drain, plastic w/slip nuts or sch 40 glued.
    By hhcibtpaun in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 04-21-2009, 12:02 PM
  2. My bathtub won't drain
    By Guest in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 03-14-2008, 11:29 AM
  3. bathtub drain doesn't line up with existing drain
    By erich in forum Shower & bathtub Forum & Blog
    Last Post: 02-25-2008, 10:40 AM
  4. Replies: 1
    Last Post: 01-06-2008, 06:04 AM
  5. Laundry drain conundrum - drain CWM into bathtub?
    By vga4life in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 04-29-2006, 06:43 AM
