Results 1 to 12 of 12
Thread: Air Chambers
    Default Air Chambers
    Are they any specific requirements in terms of locations for air chambers in the UPC? In a simple one family home where should they be - washing machines (cloths and dishes), WC? Where else? Are they a must.
    I&C Engineer (mostly WWTP) Lakee911's Avatar
    Aug 2005
    Columbus, OH
    I think Air chambers are a no no these days. They can get all mucked up if they don't fill up over time leading to stale air and bacteria getting into your potable water. Check out this article.
    http://www.builderswebsource.com/tec...aterhammer.htm
    Discussion on air chambers, causes of water hammer and squeal and hammer arrestors.
    Jason
    DIY Member Vitaliy's Avatar
    Sep 2005
    Massachusetts
    Default Info
    I had a very hard time to find a place where I can buy these arrestors:
    http://www.**************.com/waterhammerarresters.html
    But yes, they are doing the job.
    - Vitaliy
    DIY Senior Member finnegan's Avatar
    Aug 2005
    CT
    I have read recommendations against air chambers as well. Same reason - stagnant water and bacteria. The mechanical water hammer arestors are supposed to work well, but you have to place them in accessable locations. Installing your pipes carefully can help reduce water hammer.
    DIY Member casman's Avatar
    New York
    Well now I'm thinking I should replace all the air chambers in my home, is this really as bad as it sounds, are there any links to these studies, besides someone making claims about bacteria etc....Also I have a run of pipes that used to go to an upstairs kitchen. These were removed back to the shutoff valves. So there is about 6 feet or so of dead end pipes. Should these be removed as well?
    The main reason air chambers are a no-no, is that they water log.
    If you have them in the system already, I wouldn't worry about them.
    Any hardware or plumbing store should carry hammer arrestors.
    I find them where they sell the copper fittings.
    If you have a closed system, (check valves, PRV's) then hammer arrestors are required at all quick closing valves.
    These would be
    Dishwasher
    Icemaker
    Washer
    If you're wondering about stars (***) in posts, I do block some web sites.
    If you've never seen the back end stats on a board like this, you would be amazed at the number of attempts to take over and shift it into a full blown advertising medium. Sometimes 10,000 attempts per day.
    Quote: If you have a closed system, (check valves, PRV's) then hammer arrestors are required at all quick closing valves"
    Forgive my ignorance, what is closed system and the acronim PRV?
    Since the arrestors have to be accesible what would be the most suitable location for them in an One story house (in the basement/crawl space)?
    A close system is a water supply system with either a check valve on it, or a pressure reducing valve.
    Without these, the water can expand as much as it likes and in the process, pressure builds.
    Quick closing valves are generally solenoid operated.
    They are required on ALL quick closing valves.
    Washer, dishwasher, icemaker.
    Tub and shower valves are not considered quick closing.
    An approved hammer arrestor may be hidden in walls.
    We do this all the time.
    It's air chambers that need accessible drains.
    And I assume that both hot and cold supplie pipes need arresters.
    In the Trades kordts's Avatar
    Oct 2005
    exurban Chicago
    I have found that not running any 1/2" pipe in a house will eliminate the need for air chambers. When I do work that is going to be inspected, I install them. Otherwise, the minimum pipe size I run is 3/4", with 1/2" only as risers to fixtures. Water hammer is a function of velocity. Smaller diameter=higher velocity. Larger diameter=slower velocity.
    Peace out,
    Kordts
    That was my approach - running 3/4" pipe and only the risers being 1/2". But I am subject of inspection.
    And these things the inspectors like, make for a better plumbing system.
    It's a homeowner benifit.
    http://www.siouxchief.com/B_Products_Prods.cfm?ID=35
