PlumbingNovice
Just pulled up my leaky basement toilet, and it is not clear to me if it was originally installed correctly. I have a 3" PVC drain pipe cut flush to the floor (vinyl on concrete). There is no flange on the PVC, here is a picture:
On the bottom of the toilet was a wax seal. In the center of the wax seal the toilet necks down but obviously doesn't seal with the drain. The toilet setup is pictured here:
I am assuming the intent was to seal both the toilet neck and the drain so that the waste water worked it's way down the drain. But I think what happens is the water is seeping through the crack in the vinyl that can be seen in the first picture.
My question is; was this properly installed? I am assuming it wasn't since it leaks. If it wasn't properly installed, do I need to install flange to the drain pipe?
TIA
TIA
