Results 1 to 7 of 7
Thread: Explain this 3 way
    DIY Junior Member DirtIsMoney's Avatar
    Dec 2010
    Brooklyn, NY
    Default Explain this 3 way
    I have an existing 3 way in my house that is wired like this:
    Staircase..
    My feed is in the 1st floor fixture with a 3 wire going down to the 1st floor switch.
    3 wire from 1st floor switch to 2nd floor switch.. and a 2 wire from the 2nd floor switch to the second floor fixture?? I removed switches to remodel before realizing how it was wired.. An explanation would be appreciated.
    Jun 2009
    Canada
    This isn't something that should be explained over the internet.
    You shouldn't have messed with it, and now you need to hire a professional to fix it for you.
    It can get confusing...you'll need to search some 'common' diagrams on 3-way switch installation. You'll need a meter to figure out where your hot leads are before you start to connect anything back together.
    Jun 2007
    North Carolina
    Quote Originally Posted by DirtIsMoney View Post
    Staircase..
    I don’t think this can be fixed without a toaster, hair dryer and a DVM. I am sure that that guy will be along shortly to explain all this to you.
    Two lights on two different floors wired as you have proposed is impossible.
    Homeowner Thatguy's Avatar
    Aug 2008
    MD
    Each insulated wire goes to neutral, hot, a switch or the lamp. The colors will help some but with an incand. bulb, wire labels, an extension cord, clip leads and a DVM you can figure this out. But it's tedious.
    Jun 2007
    North Carolina
    Quote Originally Posted by Thatguy View Post
    You left out the toaster and hair dryer. How can they fix this without a toaster and hair dryer?
    Colors mean a lot especially the neutral and the return leg from the switch but it can’t be done without a toaster, hair dryer, drop cord, some clips, and a DVM.
    Default 3 way
    You need a voltmeter, and the knowledge of how to use it, before you can decipher which is the line, which is the load, and which are the travelers in order to make the circuit work properly. With the right knowledge, experience, and equipment, it could be done in a matter of minutes, otherwise it can be hours of frustrating hit and miss trials.
  1. Explain something to me
    By he8833 in forum Pumps and Tanks Well Forum & Blog
    Last Post: 08-13-2010, 08:14 AM
  2. Can someone explain what's going on in this panel? (Pic included)
    By Briandl in forum Electrical Forum discussion & Blog
    Last Post: 02-15-2008, 02:20 PM
  3. Would someone explain to me...
    By smhowell in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 05-20-2007, 12:20 PM
  4. Please explain flange rings
    By molo in forum Toilet Forum discussions
    Last Post: 10-08-2006, 09:25 PM
  5. Could someone explain our septic system?
    By littlebit in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 05-25-2005, 01:49 PM
