Results 1 to 7 of 7
Thread: Water filtration
    DIY Junior Member Nebbiolo's Avatar
    Dec 2010
    Chicago, IL
    Default Water filtration
    Hello,
    I am building a new home and cofused about how I want to filter my water.
    We have Chicago water from Lake Michigan. I would like to remove the chlorine.
    On some other forums, I read that using a whole house filter to remove chlorine could cause bio slime in some runs of pipe that are not used frquestly (to outdoor house bibs in the winter, basement slop sinks, etc). Is this a real concern? If so, should I just filter the water where I want to drink it?
    If I filter the kitchen water only, can I use one inline filter that will filter the kitchen sink and ice maker, but not require a special faucet at the sink? Does the filter have to be a large tank under my sink or is there something smaller that I could place in the line in the basement?
    I have tried to search for the answers, but haven't really found anything.
    Thanks in advance,
    Al
    Apr 2007
    Ontario, Canada
    As long as you use a "Carbon" filter instead of a sediment filter it will remove the chlorine from the water.
    You can use a "Whole house" or you can use it for the sink and ice maker.
    http://www.rainfresh.ca/sediment_filters.php
    http://www.rainfresh.ca/images/CF2.pdf
    Usually the easiest place to install it, AND maintain it, is in the line between the valve at the wall and the faucet's inlet.
    Yes, I would just use the inline filter if I want to filter only certain areas. The "whole house" carbon system filter can be used to get the chlorine out in general but find one thats easy to maintain.
    Have you tried the new InSinkErator?
    Garbage Disposal Reviews
    Dec 2009
    northfork, california
    Chloramine sounds like a real poison: And one of the ways to remove it from water is via superchlorination with chlorine. [!]
    http://en.wikipedia.org/wiki/Chloramine
    http://ezinearticles.com/?How-To-Rem...lth&id=5276443
    Looks like 1000 MG of vitamin C can remove the chloramine in 40 gallons of water. Sounds cheaper than carbon filters.
    Plumber jimbo's Avatar
    In my opinion, whole houes dechlorination is not a good idea. You can get things growing in ALL the pipes. Use a point of use filter for drinking/cooking, icemaker. If skin allergies is an issue, you can get a shower head chlorine filter.
    Dec 2009
    I agree with point of use, but so many of us on well water have never used chlorine and our pipes are clean and remain so.
    I chlorinate perhaps once every 5 or 7 years or when I open the cap for some reason, and of course very seriously when drilled [which so many do not] , and when you open my toilet tanks they are still clean porcelin without any colors.
  1. PEX System and Filtration
    By mvilla888 in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 03-27-2009, 01:17 PM
  2. Backwash Filtration System
    By sparker in forum Pumps and Tanks Well Forum & Blog
    Last Post: 01-09-2009, 09:13 PM
  3. EverPure Water Filtration
    By jerome8283 in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 12-01-2008, 07:06 AM
  4. water softener/water filtration
    By aftergolf in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 05-15-2008, 08:43 AM
  5. Private Well House Filtration
    By mankind in forum Pumps and Tanks Well Forum & Blog
    Last Post: 11-12-2007, 08:39 AM
