Thread: Brine refill problem
    DIY Junior Member
    Dec 2010
    Default Brine refill problem
    I have a NorthStar automatic softner model NSC29UD. I am having a problem with the brine refill. It only refills with about 3 to 4 inches of water (est. @ < 1 gal.). With so little brine water I get an incomplete regen and we run out of soft water after about 1 day. (My wife and I average about 60 gallons of water useage per day.) To prove my theory I manually added about 4 gallons of water to the salt tank and did a regen. We had plenty of soft water for a full 5 days until the next regen.
    So my question is what is causing the brine tank not to refill with enough water? How do I repair it?
    Thanks.
    Dec 2009
    Alaska
    Sounds like the float is to far dpwn and closing off the refill sooner than it should.
    Try moving that white float up the shaft some and see if that works..
    DIY Junior Member
    Dec 2010
    I checked the float and it is located properly and slides freely. I really don't think it is the float system. Could it be something in the control? I took the fill tube off at the bottom of the venturi and didn't see anything, no dirt etc. Any more ideas?
    Dec 2009
    Alaska
    Try moving the white float farther up the shaft that it is on and send the unit into a regeneration and see what closes of stops the water first, time or float and get back.
  1. cole and massey PIX 34 brine refill not working
    By evanm in forum Water Softener Forum, problems, installation and reviews
    Last Post: 11-25-2010, 11:13 AM
  2. Culligan Medalist Softener Brine Refill Cycle
    By rbeachy in forum Water Softener Forum, problems, installation and reviews
    Last Post: 10-27-2009, 03:39 AM
  3. brine softwater problem
    By softwateruser in forum Water Softener Forum, problems, installation and reviews
    Last Post: 04-22-2009, 11:51 PM
  4. brine softwater problem
    By softwateruser in forum Pumps and Tanks Well Forum & Blog
