Results 1 to 8 of 8
Thread: culligan mark 59. should i keep or fix it?
    DIY Junior Member
    Dec 2010
    iowa
    Default culligan mark 59. should i keep or fix it?
    I have a culligan mark 59 aqua sensor water softener. I have had it since 1982? The timer keeps stopping and I got to whack it to get it going. The culligan guy said I should get a new unit because they don’t make parts for the 59. Also said my tank needs cleaned out because it is restricting my water flow. They can clean my tank and but new stuff in it for $500. or a whole new unit for $1300.
    What do you think?
    Dec 2009
    Alaska
    Is it just the timer that is giviing you challenges?
    Might be a simple replacement of either the timer assembly or the timer motor.
    DIY Junior Member
    Dec 2010
    iowa
    timer is the big problem. culligan said they cant get a timer anymore. do i have other options?
    Dec 2009
    Alaska
    Find some one that has a used timer.. might you be able to post a photo or send me a photo?
    I am trying to remember if your timer is the same as the mark 89 timers of that time frame.
    On an update, found a Culligan Mark 59 manual, and from what I can tell.. the timer looks to be the same at the mark 89 etc timer...
    The wires might be a bit different on the back side ... but I think that it should work.
    Homeowner Thatguy's Avatar
    Aug 2008
    MD
    Yes, post diagrams of the original timer chart
    http://www.google.com/imgres?imgurl=...1t:429,r:7,s:0
    and from there a replacement with jumpers can be made to work.
    DIY Junior Member
    Dec 2010
    iowa
    Thanks!! do you or anybody have one?
    DIY Junior Member
    Dec 2010
    iowa
    i will try to post pic later today.
    Dec 2009
    Alaska
    We look forward to the post of the photo or the answer to the pm.
  1. Culligan Mark 812
    By 01jordyn in forum Water Softener Forum, problems, installation and reviews
    Last Post: 04-27-2011, 08:41 AM
  2. Just moved and reinstalled Culligan Mark 100 and Have Some Resin in Backwash
    By jkmason in forum Water Softener Forum, problems, installation and reviews
    Last Post: 07-01-2010, 10:32 AM
  3. Culligan Mark 812 stuck in regeneration
    By Joleene777 in forum Water Softener Forum, problems, installation and reviews
    Last Post: 01-03-2010, 10:17 PM
  4. Culligan Mark 812 Water Conditioner - Time to replace?
    By rstier in forum Water Softener Forum, problems, installation and reviews
    Last Post: 08-06-2009, 08:09 PM
  5. culligan mark 812 knocking noise
    By elkel in forum Plumbing Forum Discussion & Blog
    Last Post: 11-05-2005, 12:32 PM
