Results 1 to 5 of 5
Thread: Possible Bad Control GE GXSF27E
    DIY Junior Member
    Dec 2010
    southern us
    Default Possible Bad Control GE GXSF27E
    I am getting error code 1 on my ge softener. It is 6 years old.
    I have replaced the resin, seal kit, disk rotor, switch and motor and am still getting the error. I get the error even if I run the unit in bypass mode. I also get the error even if the switch is disconnected. It always stops when it hits the BW indicator on the cam gear. Also as soon as I plug in the unit it immediately goes into regenerate now mode and I can not get it to not be in that mode.
    To me it looks like the only part left that could be bad is the control unit. Any suggestions???? Much thanks in advance.
    Scott
    Resin can't cause error codes.
    If you can't find out what the error code 1 is about, you probably should call Sears for service. Your GE uses the same valve, tank, bypass valve, resin etc. and parts are interchangeable. It probably is something with the circuit board.
    DIY Junior Member
    Dec 2010
    southern us
    Gary, thanks for the reply. I understand it is not the resin, originally I had bad resin and just passing along all the changes I made. I am just asking if it could be anything else besides the control( or circuit board) at this point. I am ready to buy the circuit board but it is $200.00. thanks again.
    Scott
    I wouldn't put that much money in a GE, Sears etc.. You should look into buying a new softener with a Fleck control valve like the 2510 or 5600 SXT. You can get parts and info from many sources at reasonable prices. And your $200 is half or so of the price of a new softener bought online. And install it yourself.
    DIY Junior Member
    Dec 2010
    southern us
    Gary, thanks for input. I am weighing the fact that I have already spent a lot of money unfortunately repairing my softener. At this point it is pretty much brand new with almost all of the prats replaced except the brain. Thanks agian.
    I was able to get another control and wiring harness from another unit. I am still getting error code 01 with the new control board. So somehow I must have something together wrong to cause this issue.
    I put the switch in wrong. The spacer needs to be on the top and not the bottom of the screw. I now have soft water.
    Scott
  1. Well Pump Control Box
    By SRSPRINT in forum Pumps and Tanks Well Forum & Blog
    Last Post: 04-12-2010, 08:43 PM
  2. Air Control Valve
    By Chrisw1958 in forum Pumps and Tanks Well Forum & Blog
    Last Post: 03-18-2010, 01:59 PM
  3. control box issues
    By tab in forum Pumps and Tanks Well Forum & Blog
    Last Post: 12-31-2009, 10:40 PM
  4. Do we need Gun control YET?
    By Cookie in forum Computers and Stuff
    Last Post: 04-17-2009, 11:02 AM
  5. well control box
    By wellzombie in forum Pumps and Tanks Well Forum & Blog
    Last Post: 07-23-2007, 10:12 AM
