Thread: Sump pump sizing survey
    Homeowner Thatguy's Avatar
    Aug 2008
    MD
    Default Sump pump sizing survey
    hp of your pump?
    nearest big city?
    how many consecutive years has it been able to keep up?
    how often over how many years hasn't it been able to keep up?
    Even five answers would be good, depending on how much the data is scattered.
    Thank for your help.
    Jan 2008
    1/3 hp
    Milwaukee
    never
    I would speculate that in 99% of basement floods, the problem was never that the the sump pump could not "keep up".
    The flood comes after the switch or motor fails because it cycles too frequently.
    Aug 2008
    MD
    Thanks for your input. As soon as I can find the paperwork on mine I'll have all of two datapoints! For the DC area mine has worked at least since '92.
    A reasonable range of sump pump sizes seems to be from 1/6 to 1 hp.
    With a range this large, either a single variable speed pump or two pumps, one small and one large, may be the solution to prolong pump life. To prevent the large pump from seizing up from lack of use a little $20 circuit could goose the thing for a minute or so once per week or once per month.
    Based on cost/risk/benefit it seems like a sump water level alarm is also a good idea.
    I couldn't seem to find any recent patents on sump pump improvements.
    I'd think the pump(s) should be able to handle a rainfall event or flood event that returns only every 10 years or 20 years and that info is available for major cities.
    100 year returns for Juneau, Alaska is 0.6" and 6.2" for Hilo, Hawaii. This is also a pretty wide range.
  1. SURVEY: Recirculating Pump and Leaks - How many years?
    By proxybox in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 05-22-2011, 11:43 PM
  2. Sizing sump pit for external french drain
    By Teehee99 in forum Pumps and Tanks Well Forum & Blog
    Last Post: 05-15-2010, 07:46 PM
  3. Correct height for sump pump inside sump pit..??
    By davenay67 in forum Pumps and Tanks Well Forum & Blog
    Last Post: 11-14-2009, 06:59 AM
  4. Sump Pump Basin Sizing
    By soccer123 in forum Pumps and Tanks Well Forum & Blog
    Last Post: 04-12-2009, 06:56 PM
  5. Reputation of ABS Robusta sump pump / sump pump configuration issues
    By ct-esq in forum Pumps and Tanks Well Forum & Blog
    Last Post: 12-29-2008, 06:41 AM
