It's normal. When the water sit in the line, it loses heat. All of that cool water has to be purged from the line by the incoming hot water. The larger the pipe and the longer the distance, the more cool water there is to be flushed out, and if you have 3/4" pipes, there is almost twice as much water as there would be in a 1/2" pipe. There are a couple of ways to deal with this. If there is access to put a return line from the most distant fixture to the water heater, a recirculating system works very well. You have virtual instant hot water as long as the pump in the system is operating. Some pumps are on a timer, some are not. There are other devices that do not require the return pipe that work pretty well also. I am most familiar with the system with a return line. I do not have a timer so the pump runs 24/7. It has been in place for about 8 years and shows no sign of wearing out. Of course it will someday, but replacing the pump will be a 5 minute job (after I get the pump)
