Results 1 to 2 of 2
Thread: "singing" - not banging - zone valve
    DIY Junior Member
    Dec 2010
    USA
    Question "singing" - not banging - zone valve
    Couldn't find anything on the web on this.
    Our heating system is a hot water baseboard system. The boiler feeds into an air scoop, then a Taco bypass zone valve. The "bypass" outlet goes to a manifold with two Taco zone valves, one for each heating zone. The "controlled" outlet goes to an indirect fired water heater. The piping has been in place for 26 years, the boiler and water heater were replaced about four years ago. Starting with this heating season, the system has been making a "singing" sound that can be heard throughout the house. After somewhat extensive investigation, I've discovered that the noise only occurs when both zone valves to the heating loops are open. Additionally, I believe I've narrowed the source of the noise to the bypass zone valve. What I can't understand is why it's just starting after 26 years and why only when both heating zones are calling for heat. Any ideas?
    Homeowner Thatguy's Avatar
    Aug 2008
    MD
    Quote Originally Posted by yodayoda View Post
    An internal part has become loose due to normal wearout? The higher the frequency the smaller the part.
  1. Replies: 3
    Last Post: 08-09-2010, 06:44 PM
  2. multi zone supply & return spacing 8"... 4" ??
    By hottubbrad in forum HVAC Heating & Cooling
    Last Post: 12-24-2008, 10:41 AM
  3. Irrigation Solinoid Zone Valve "Hammering"
    By GeorgeM in forum Irrigation / Sprinkler Forum
    Last Post: 10-17-2008, 07:30 AM
  4. Delta Monitor 1700 (1768) "Graves" tub/shwr valve
    By holybuzz in forum Shower & bathtub Forum & Blog
    Last Post: 01-13-2007, 08:03 AM
  5. "Singing/Whiring" Water Pipes
    By ironwmnmk in forum Plumbing Forum Discussion & Blog
    Last Post: 08-07-2005, 04:27 PM
