Results 1 to 6 of 6
Thread: richard
    richard
    Dec 2010
    sheboygan wisconsin
    Default richard
    I have a problem with my well. the well pump is a pentex 10sp4co2j-04 pump.5 yrs old.A 30/50 pumptrol presure switch (new) and a wx205-well-x-trol presure tank.(20yrs0ld)
    The problem is that the water flow stops completely for a second till the presure switch kicks in. 30lbs.
    then i have water cause the pump is now working, i have the tank set at 28lbs.
    It also takes about 2 minutes for the pressure to get to 50lbs.
    I also changed pressure gauge then the pressure readings were 20/ 40
    any ideas
    Jan 2008
    Where is the pressure gauge installed in the system?
    I would start be removing the pressure switch and making sure there is no blockage in the pipe. It is common for the small line to become restricted.
    Moderator valveman's Avatar
    Mar 2006
    Lubbock, Texas
    If you have a 20/40 switch with 28 PSI air in the tank, you will always see the water stop coming out the faucet before the pump starts. Let the air out to 18 PSI, or turn the pressure switch up to 30/50.
    And if you have already set the 30/50, increase it a lb or two (turn the tall screw's nut 2 rotations CW [tighten]) and see if that doesn't solve the problem.
    When done see what the cut off pressure is and adjust the short screw if needed (up is CW/tighten).
    richard
    Dec 2010
    sheboygan wisconsin
    Thanks guys for all your help. I did what everyone sugested still the same. But i noticed that when the pump shuts off at 50psi thee pressure on the gauge continues to rise up to almost 75psi.is thee wel-x-trol shot I need help
    Mar 2006
    Lubbock, Texas
    Then cacher_chick is probalby right. Rare for a bad tank to do that.
  1. Funny plumbing movie by Richard Rosenman
    By Terry in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 08-14-2005, 11:42 AM
