Results 1 to 2 of 2
Thread: Navien i can fix your problem!!!!
    DIY Junior Member
    Dec 2010
    Texas
    Default Navien i can fix your problem!!!!
    If you are having troubles with your Navien system cycling on and off or going cold , I can help. I found the problem to be a vacuum issue. After talking to tech we determined our house being foam insulation type was too air tight. So I removed two bottom screws from the cover of the Navien system. I then placed to plastic spacers about 1/4- 1/2 inch in size and used longer screws to attach. The cover now stays open from the bottom. The unit works perfectly has never gone out again. That was over one year ago. You could just take the cover off but I feel better with it just open at the bottom. You must use a firm spacer because the vaccuum is so strong it will close with a soft one. Try it I think you will find it works!!
    In the trades Dana's Avatar
    Jan 2009
    See my response to this thread where it was posted on the tank heater forum:
    http://www.terrylove.com/forums/showthread.php?39443-Navien-i-can-fix-your-problem!!!!
  1. Navien Tankless Water Heater Comments and questions
    By willl in forum Tankless Water Heater Forum
    Last Post: 04-28-2013, 10:16 PM
  2. Navien i can fix your problem!!!!
    By Bryan Texas in forum Water Heater Forum, Tanks
    Last Post: 12-13-2010, 08:00 AM
  3. Navien Intake Air Problem
    By alinford in forum Tankless Water Heater Forum
    Last Post: 06-28-2010, 10:16 AM
  4. Navien for commericial use
    By dipstick209 in forum Tankless Water Heater Forum
    Last Post: 02-26-2010, 01:40 PM
  5. Navien pressure valve
    By Kiisu in forum Tankless Water Heater Forum
    Last Post: 11-03-2009, 10:29 AM
