1Norcal
Would someone please offer some advice before I break something. I have searched around the site for info, but I can't figure out what I'm doing wrong. I have a well which I have been using for a few years for my animals on some rural property. 300 feet deep, 1 1/2 submersible pump around 280 feet, check valve on top of the pump, another check valve 200' up, storage tank at the well casing with a hose bibb, pressure guage, pressure switch. This set up has been working great for my occasional usage. Heres where I created a problem. I set a storage tank 250' +/- away and maybe 75' up in elevation and ran several pipes to and from. I plan to install an ozone setup in the tank and booster pump the water to my houshold usage. My problem is with sub pump filling the storage tank. I removed the pressure tank to use it on my booster setup. I have purchased some tank fill switches, but have not installed them yet , need to pull the wire. I have been trying to throw the breaker to fill the storage tank. When I do there is a large surge as the pump turns on, then the pump runs ok. But when I turn the pump off water hammer hits hard at the well head where I am standing and water starts hammering out of the pressure relief valve. I first had a 1 1/4" pipe from the well to the tank. I thought maybe it was too much additional weight so yesterday I switched to one of the 1" pipes I had installed. Didn't help. I'm at a loss with this and am scared to turn the pump on again in fear that I will break something. Any help would be greatly appreciated.
