Page 2 of 2 FirstFirst 12
Results 16 to 22 of 22
Thread: Can you help troubleshoot my hot water/high electricity bill issue?
  1. #16
    1. I NEVER test an element with an ohmeter
    2. You should ALWAYS remove the wires from the element if you are testing with an ohmeter, which should eliminate any problem with corrosion, since you would NOT test on the screw.
  2. #17
    Homeowner Thatguy's Avatar
    Aug 2008
    MD
    After prepping the contact points with fine sandpaper I use ohmmeters because of zero shock risk, but they do have their limitations.
  3. #18
    Dec 2009
    northfork, california
    I have elements with holes in them that apparently leaked the electricity to ground rather than heated the water. Just not enough to trip a breaker. Go figure.
  4. #19
    Aug 2008
    MD
    So there was current flow in the pipes to ground. 10' of half-inch ID copper pipe has a resistance of . . .I forgot. When this wine wears off I can probably tell you.
    Or not.
  5. #20
    quote; I have elements with holes in them that apparently leaked the electricity to ground rather than heated the water.
    When that happens one part of the element operates at 120 v. If it is the WRONG half, then it bypasses the thermostat and overheats the water until the "ECO" pops out. It is a COMMON problem, but is easily detected with an ammeter. WHich is why I use that instead of an ohmeter.
  6. #21
    Dec 2009
    I use an ammeter too. Just installed 2 new 4500w elements. [both operate together]
    1 element; 17.8 amps on one wire, 19.9 on the other
    1; 18.5 a on one side, 20 on the other.
    Seems they should read the same on each wire. Never seem to. Whats up?
  7. #22
    Aug 2008
    MD
    100x20/17.8= 112 % so the tolerance on the hot resistance value for elements is maybe (112 - 100)/2 = +/- 6 %, assuming this small sample size of 4 is representative of all 4500 W elements. Probably the actual tolerance is quite a bit wider than 6 %.
    Close enough for guvmint wuk!
    And the cold [or hot] resistance values for "identical" brand new incand. bulbs is probably all over the map but the hot values may have tighter tolerance limits.
    Not much precision required in either case and precision costs money.
    http://statpages.org/tolintvl.html
    The likelihood that you would get two consecutive element readings identical to within 1 % or 0.1 % is probably close to zero.
    And this book
    http://www.probability.ca/sbl/
    says you're more likely to die in a car accident on your way to buy a lottery ticket than you are of winning that lottery.
  1. Leak causing high water bill Please Help
    By Stlouisfan in forum Shower & bathtub Forum & Blog
    Last Post: 06-21-2009, 03:28 PM
  2. crazy high electrical bill
    By adams211 in forum Electrical Forum discussion & Blog
    Last Post: 01-01-2008, 07:49 AM
  3. My water bill is too high!
    By Randyj in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 07-17-2007, 12:14 PM
  4. Need help with high gas bill.
    By enviroko in forum HVAC Heating & Cooling
    Last Post: 05-04-2007, 01:15 PM
  5. Reliance water sending electric bill sky high
    By sivright in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 02-05-2005, 01:31 PM
