Results 1 to 2 of 2
Thread: Navien i can fix your problem!!!!
    DIY Junior Member
    Dec 2010
    Texas
    Default Navien i can fix your problem!!!!
    If you are having troubles with your Navien system cycling on and off or going cold , I can help. I found the problem to be a vacuum issue. After talking to tech we determined our house being foam insulation type was too air tight. So I removed two bottom screws from the cover of the Navien system. I then placed to plastic spacers about 1/4- 1/2 inch in size and used longer screws to attach. The cover now stays open from the bottom. The unit works perfectly has never gone out again. That was over one year ago. You could just take the cover off but I feel better with it just open at the bottom. You must use a firm spacer because the vaccuum is so strong it will close with a soft one. Try it I think you will find it works!!
    In the trades Dana's Avatar
    Jan 2009
    A house that tight should
    A: only use sealed-combustion direct-vented type heating appliances- relying on conditioned space air for combustion in a super-tight house is a recipe for higher carbon monoxide in the exchaust and potential backdrafting.
    and
    B: have an active ventilation system for ensuring a minimum level of air exchanges in the house (preferably a heat recovery/energy-recovery type venilator. ERV, if you're anywhere near the gulf-coast, since it'll strip some of the summer humidity out of the ventilation air where HRV won't. The humidity is less of an issue in the panhandle or west of the Pecos than it is from the Red River valley down to Brownsville. If your summertime outdoor dew points are north of 65F most of the time, ERV is by far the better bet.)
    Atmospheric-drafted units need to be carefully assessed for backdrafting potential. Run all of your bathroom & kichen fans and the closthes dryer too, and use a smoke-pencil or incense or something to verify that no air is coming back down the exhaust plumbing on the burners, both when firing and not. If you have central-air or hot-air heating, test with & without the air handlers running as well.
  1. Navien Tankless Water Heater Comments and questions
    By willl in forum Tankless Water Heater Forum
    Last Post: 04-28-2013, 10:16 PM
  2. Navien Intake Air Problem
    By alinford in forum Tankless Water Heater Forum
    Last Post: 06-28-2010, 10:16 AM
  3. Navien for commericial use
    By dipstick209 in forum Tankless Water Heater Forum
    Last Post: 02-26-2010, 01:40 PM
  4. Navien Tankless and Hot Water Circulator
    By mn4az in forum Tankless Water Heater Forum
    Last Post: 01-29-2010, 10:39 AM
  5. Navien pressure valve
    By Kiisu in forum Tankless Water Heater Forum
    Last Post: 11-03-2009, 10:29 AM
