kailor
Q1: What is the best product to use when insulating CPVC pipes under a mobile home?
Q2: If it is the rigid foam pipe sleeves sold at Home Depot, can the hot and cold pipes be insulated all the way to the surface of the electric hot water heater?
Q3: The trailer has skirting around it. Would the rigid foam by itself be enough to keep the pipes from freezing?
Q4: I'm fixing up the entire trailer to rent out again. Would you replumb with PEX?
Q5: If yes to Q4, I would want to use flairit compression fittings. Would this type fitting be OK?
