Vonerific
Well, sad to say I had my new AM Cadet 3 installed yesterday, (professionally, by a plumbing company, not DIY) I HATE it!... i did 2 months investigation on toilets, and narrowed it down between the Toto Drake and the Cadet 3. the ONLY thing that made me go w/ the cadet 3 is the repitition in remarks saying that it is hard to keep the Toto Drake Clean because of its design.
All of the negitive comments about the Cadet seemed to be more personal, and I thought "those wont ALL happen to me"... after all, i just wanted a toilet to FLUSH good, and with that being said, i am here to confirm all the comments about the Cadet 3 by American Standard.
Pros: It flushes great!
Cons: A. It DOES sit 4 inches away from the wall, looks stupid.
a. the toilet i had prior was larger, but still a 12" rough, and i live in an apartment and the only way to make it NOT be 4 inches from the wall was to cut a new hole and reposition it, and being in an apartment we couldnt do that. (although weve had other 12" rough's that have installed just fine, the cadet 3 is just off)
B. The tank does NOT fit securly, it wobbles. If you keep screwing down the bolts, the plumber said the porcilan will crack. We have shimmys all around it, and stirofome stuffed all around it. In a couple days we can try to tighten it more, but he put his wieght on it, and everything, and it will not go down far enought to touch tank to base.
C. the lid to the tank does not even fit., good thing we have a hutch over our toilet to cover the back half because there is about a 1/4 of an inch sticking out where the lid doesnt cover, and when you sit on the toilet and sit back... it pushes the tank lid to the back so each time you get up, you have to repossition the lid, and slide it forward or elese the crack is in the front!
D. the tank has a forward lean to it, so it also just looks wierd, and off....
All around, i just hate this toilet and now im stuck with it. Its from the apartment complex i live in, and unless i want to fork out ANOTHER 300.00.... im stuck with this. (I broke the other toilet, so i had to go in on halfs w/ the apartment manager for this one).... i cant belive all this drama over a toilet, and that it has caused me so many nights of not sleeping. At least its in, and i know the outcome....now i can just work on getting over it.
I hope this helps anyone who's been looking at a Cadet 3.
