Results 1 to 5 of 5
Thread: manabloc with master shower
    Default manabloc with master shower
    Hello,
    I am in the process of installing the plumbing for our new master bath. We will install a Manabloc manifold with a 1/2" PEX going to the shower. We plan on using a Moen shower setup with a showerhead, diverter and 4 body sprays. Is there anything we can do to make sure we have adequate pressure?
    You'll need bigger than 1/2" pex for that.
    Can you run 3/4" from the Manabloc or is there another way to do it?
    If the Manbloc has 3/4" ports, run that, or even 1". You can convert it to the valve side when it gets there. Just upsizing the pipe if the port is small will help, but it's not the same as having a larger port. Keep in mind that pex has a smaller ID than copper, PLUS, the fitting fits inside of it, further reducing the max flow.
    DIY Junior Member DirtyDen's Avatar
    May 2011
    Colorado
    Default High Volume fixtures
    I realize this is a bit late as you are most likely beyond the changing point, but for those who may have similar questions in the future. The easiest solution is to run two 1/2" lines and use a bullhead tee (1/2x1/2x3/4 tee). This generally supplies enough water for those high volume fixtures (not the eight headed monster). As stated in prior posts, pex does have a narrower id (inside diameter); however, if installed as a homerun (not exceeding the specified lengths), the elimination of fittings more than overcomes this restriction. Every change of direction adds to the pressure drop in the line regardless of material. With pex, there is no change in direction (unless fittings are used). So, if you are using pex in a traditional method (2 pipe/branch&tee), be sure to look at the charts to determine if you can get there with 1/2".
    There are no 3/4" or 1" port on the Manabloc.
    P.S. this also is the solution for large tubs.
  1. Shower master valve leaks
    By pbroughton in forum Shower & bathtub Forum & Blog
    Last Post: 01-16-2010, 05:28 PM
  2. Master shower water does not heat up
    By Sam Grable in forum Shower & bathtub Forum & Blog
    Last Post: 01-07-2010, 05:10 PM
  3. Hot Water Setup / Master Shower
    By khargis in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 01-23-2008, 06:32 AM
  4. sewer gas in master shower drain ???
    By mkpaluv in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 08-20-2005, 10:11 AM
  5. master shower leak at one corner
    By xchen in forum Shower & bathtub Forum & Blog
    Last Post: 05-12-2005, 04:10 PM
