OK, a little background first. House was built in 1942, I have been here for 20 yrs with no issues. I doubt its vented properly to begin with but haven't had an issue until now. Upstairs toilet drain makes 90 degree turn then runs along floor to outside wall, sink and tub drains connect to toilet drain before it makes another 90 degree turn to run down wall to 1st floor. Right where the upstairs drain turns to go downstairs there is a vent pipe connected that goes outside and up the wall. This is the part that I believe is incorrect, the vent is between the upstairs and downstairs plumbing and I don't see any vents above the upstairs plumbing. Starting a few days ago when I flush the upstairs toilet I hear a gurgling sound from the upstairs shower drain. Last night I noticed the downstairs toilet water level in the bowl is low and sewer smell from the downstairs shower, seems like a vaccuum pulling water from the traps and out to the street. Water level in the upstairs is normal. When I flushed the upstairs I noticed the downstairs toilet water level going up and down and the laundry tub trap making sounds. Now this is the weird part but I'll try to describe, maybe take pics when I get home. Years ago I noticed a plastic hose about 1/2" OD connected to the top of upstairs toilet drain where it turns to run along the floor, between upstairs toilet and outside vent. I followed the hose about 30' across the 1st floor ceiling (easy to trace, removable ceiling panels) where it just ended, not connected to anything. I had no idea what it was for but thought that it would be a good idea to seal up the end with tape so no gasses would come out of it, this was about 15 years ago. Last night I removed the tape and when flushing the upstairs I no longer get sounds from the shower, basement toilet water level and shower drain are normal now. Seems like I was adding a vent by removing the tape from the hose, thats why I think the main vent may have something in it like bugs, small animal, rust flakes?. I hope the main drain isn't blocked because that is over my head and would need to call a professional. Let me know what you think. Thanks
