Sure, they can share the same drain. As for the boiler though, if you do not have a drain handy, you can use a condensate pump. I have the following one on my A/C http://www.waterace.com/specialty_2.html ($40 at the Blue Box). This pump probably wouldn't be able to handle all but the smallest leak/overflow from the washer so it's not for that. You could use something like this though in lieu of the pan: http://www.smarthome.com/7115.HTML.Originally Posted by fishbum
It depends on the layout of your house. It's hard for anyone to suggest a location without any information about your current plumbing layout. You'd want to have a trap of some sort for each one unless there is some method of keeping sewer gases from backing up into those fixtures.Originally Posted by fishbum
Jason
